Bradracer18
A few general pulling questions, mostly John deere related:
I've got a john deere 70 so answer in regards to that.
1. Can a guy find aluminum rear wheels (where/price?) and if not, what does it take for the pressed steel wheels (and what size/dish do you want)?
2. Aluminum front wheels, how are guys putting these on with a 6 bolt front hub/stock hub.
3. Tractor has bad brakes....is there anything aftermarket/pulling related that I can throw on there...or should I just replace with stock components?
4. Weight brackets. I've got a good idea of how to build the front one, but anyone got any helpful pics? I've built the rear ones also, but looking for a way thats easy to remove yet uses all 4 studs. Also, can you use aluminum for the rear weight brackets....if you'd happen to need them removed for light class?
I'm sure I've got more questions but thats a good start...
Thanks!
Thanks!
