1949 C weight
Dougct
It will be my first year pulling with my 49 C.It has fenders,wheel weights,wheelie bars,narrow front and hydrolics.I weigh 200lbs,any idea of a weight it will come in at?I need to be 3500 should i strip the weights before i go?Thanks
My book says 2710 shipping weight when new so you should be good. You could probably make 3000 without the weights.
Are we talking A-C or Farmall "C"? Either one will make 3500 easily. But the Allis is much easier to get to 3000.
I would agree with Andrew, I have a 53' Super C with the fast hitch. It is the tricyle front end with 2 35# wheel weights. I weight 230 and 1/2 of gas I was right at 3460.
If your 220 and the scales are good you can make 3000 if they allow you a 100 over if its 10% then its going to be close for 3000 and easy for 3500. You are better in the 3000 if they have it. 3500 for a stock C is pushing it.
