1955 Oliver injection pump in 4010 JD
Anonymous-0
I have a 1955 Oliver (rosamaster) pump, looks like it will bolt up to a 4010 JD with very little trouble. Any thoughts on this? Thanks
My brother once found a bunch of roosa-master pumps that were army surplus. New wraped up in cosmuline. Some were 3 cyl most were 6 cyl and 4 cyl. He rebuilt pumps for neighbors for years with these. The rotation is different on some engines. This can be overcome also. Yes the pump will work. Be sure and check the rotation. If the Oliver pump has a advance, will need to back the timing back to 4020 specs.
