John Deere G Gear Reduction Starter
Brent50G
Does anyone know what starter the “Fist Full of Dollars” JD G uses? I was told it was off a newer john Deere but that’s pretty much all I know. I know it is gear reduction and it seemed to crank the tractor really well when I saw it at White Pine TN. I believe that some of the Drummonds pulling team may use the same starter. It looked like it bolted right up with no modifications. Thanks for the help.
I have been useing a delco starter off of a 1100 massy ferg diesel. aprox 240 lbs of comp,good bat an comp relece starts ok
