195 GK Waukesha Questions
Anonymous-0
I bought a 195 GK power unit and I'm missing the rocker arms and the manifolds. Will 88 oliver rocker arms, shaft, and stands fit the 195? Also I would like to put this in a 77. Will the big 1100 massey manifolds fit under my hood and side sheilds? Any other input on this install in a 77 is appreciated.
Thanks,
Ray
power unit manifolds will fit under 88 dont know about 77 will be tight 1100 massey ex. manifold is to big for a 88 ,do you have a 1100 our a power unit engine a power unit is alot easier to bolt in rocker arms on power unit engine have same # stamped on them as 88 stands loook different 1100 rocker arms are cast totallt different give me a call 618 246 6030
There were 3 different styles of 88 rocker arms used. You need the late style. Get a set off of a Super or an 880 and you will be safe. Pushrods and rocker shaft supports are different.
