Building a mild 310 and have a couple ?
Can I bore the original sleeves to 4.0"?
If I use 77 rods and offset grind the crank how much stroke can I gain?
Will 77 rods fit sbc or sbf pistons (bushed down on the pin)?
I will have roller rockers and just some clean up on the heads and intake. What compression is reasonable with out using racing gas all the time?
This will be going in an 88 15.5 151s top cut
Pulling 4500-7000lb. classes with a 3.5mph speed limit
Plus classes 4000-6000lb classes with 4.5mph limit
