Little B John Deere
Sounded like it may have done OK in 2nd..!
I think I would save the upper RPM for later down the track..!!!
Pulls real good..!!!
Ron..
I haven't pulled my styled "B" 1950, for some time but it use to run like that for years. I have run a 1950" A" like that for 25 yrs now. Tater .
looks real good.
A few months agoe we talked about a cylinder head project that I had done, the B runs like it's got something pretty good feeding it.....
Holly-Molly, man..what RPM are you letting that JD Turn..!!!
If that flywheel decides to come out..it ain't gonna be pretty..
It is pulling very well..try to make it last..!!
Ron..
(quoted from post at 02:55:10 09/30/11)
(quoted from post at 01:44:04 09/29/11) Here is a video of my newest version of the B last weekend,
http://www.youtube.com/watch?v=llBNttymH48
Let me know what you guys think, Derek Holdren
Next time you video it tell the guy not to stand next to a generator, you can't hear the tractor over the buzz of the genny.
What's the bore/stroke? Looks like you put a 50 block and head on it.
Its 4.75/8.125. Good eye, Its a 50 block and head indeed.
(quoted from post at 03:38:32 09/30/11)
Ron..
The fly wheel has a heavy shroud around it for when it lets go.. a blanket over the pulley too.. It spins hard enough to go 4.9mph in first gear haha.. In the 4000lb class it was in second gear, and in 4500 it was in first. The whole thing was just an experiment too see how well the setup would work. After harvest I'm gonna pull it apart and set it up to run mph/rpm regulated classes this spring.
Derek Holdren
