Kyle Ladowski
Does anyone know the dimensions of some of the larger Minnie Mo rods? Possibly the MM U rods? I thought someone told me that they put U rods in their MH 55 and could offset grind the crank some. I am having a problem getting pistons made for my 55 because the distance from the center of the piston pin to the top of the piston is 3.625, the forging will only take a max of 4.520 bore and that is only .020 oversize on the bore. I'm not sure my sleeves will clean up at +.020. It has been suggested to get longer rods and or stroke it some to get the piston shorter so I would have more options on the pistons.
Any ideas? I'm not looking to go pulling much, maybe a few times a year, but would still like to be able to do some plowing with it.
Thank you,
Kyle
Thank you,
Kyle
