I've got a '45 JD A that pulls great in the 4500/5000lb class but runs out of juice for the 5500lb class.
I'm borderline in the 4500lb class and stripped down. Not too much fun pulling when you can't use some weight to balance it. Although it does very well in this class. 5000lb class is perfect being able to toss around a few lbs. Usually finish top 5. Most pulls around here are 4500 and 5500 so I either pull stripped down or weigh up and suck.
Motor is fresh, bored, good pistons, runs strong. Tires are 14.9 38's on 16" rims. Most tracks are heavy wet clay too.
I really feel like I need more gear. If the balance is right in 5000 it will pull till it stalls, 5500 always stalls.
Other than going with a smaller tire, what else can I do?
Can you swap the later A lower gear into my '45?
