Mapleton MN Pull sunday June 12th
ReedA
Sunday June 12th
Registration at 9:00 pull starts at 11:00
Hot Foot II sled
Farm stock class 4500, 5500, 6500, 7500 and 8500lbs
Stock class 4500, 5500, 6500, 7500, 8500, 9500 and 10,500lbs
Open class 4500, 5500, 6500, 7500, 8500, 9500 and 10,500lbs
Questions email [email protected]
(quoted from post at 13:23:34 06/07/11) What is the difference between stock and farm stock?
Farm stock does not allow homemade weight brackets, suitcase weights. pulling hitches. All weights must be factory. Drawbar is 16" high with a clevis only. Tires are one size over stock. It's basically for locals to bring in their tractor and pull.
Stock allows add on weight brackets, suitcase weights, pulling hitches at 20". Tires are no cuts, 18.4-38 tire limit.
(quoted from post at 13:27:37 06/08/11) Reed.. dad said he is going to try to make it... Do you have a spare tractor... haha..
I plan on having the 720 there, the G is scheduled for a hayride. If your dad is there he can certainly run my 720 for a hook if he wants.
