I'm putting the final touches on my Massey Harris Mustang puller. I've got it running and plan to dyno it on Tuesday. It runs ok, but surges a lot and it appears to be starving for fuel. I've got a good supply of fuel to the carb, but the load needle has no effect on fuel/air mixture at high idle (or under load for that matter). I can unscrew it all the way and the engine still runs lean. When I tighten it down, of course the engine stalls.
The engine is a Continental F140 that's been bored to 168 cubes and compression has been increased quite a bit. Do you think it runs lean because the carb is designed to feed 140 cubes and now it needs a bigger main jet? I measured the jet hole around .040 inches and I'm considering drilling it bigger. Any thoughts on this would be appreciated.
Zack
Zack
