1950 styled A
Tater
I am currently using a #3 power block and I want to go to a 6.5 bore can it be done. Murphy's say i have to redrill for #1 or #2 block.
Thanks.
p.s.
emails open
Are you wanting to use one of their blocks?? Depends on what crankcase bolt pattern they have.. could have big sleaves welded into your block..
The reason for using the earlier block-crankcase bolt pattern is because the larger sleeves will not fit in the confines of the late A/60 bolt pattern. Remember there 8 bolts to deal with instead of 6, and the upper side bolts are the problem. Hope this explains things. Mike
