Anonymous-0
Hey folks, I know there a bunch of you out there that have put a 310 gas in a Oliver 88, so I am hoping that some of you may be able to help with the headache. I had a Delco 1 wire alternator on my 88 motor. When trying to put the 1 wire on the 310, the housing is hitting the bypass hose coming off the water pump going to the thermostat housing. I have been to the local parts store with no luck. I also went to a specialty store, and may have found a alternator with a smaller body, but not sure yet. I realize that the brackets will have to be fabricated, but I was wondering if anyone knew of a particular alternator that would bolt up, or if there is an alternate way to mount it that I am not looking at, and is that bypass hose necessary? From what the service manual says, it sounds like it needs to be on there, sure would be easier if it wasnt there. Just to clarify, I am putting this together with the original side curtains in place, so that is the reason for the problem. Also, the 88 cooling system is a non-pressure system while the 310 system is a pressurized system that requires a 7 lb cap. From what I can gather, the 310 needs a certain amount of pressure to open the thermostat. Is this info correct, or can I use the 88 radiator with the non-pressure cap? I know that these questions may be trivial to some of you experienced builders, but any help would be appreciated.
