SMTA
Can I but a crank to stroke my Super Mta using same rods and piston. I don"t want to have to grind anything off of the block. Also where can I but one.
Thanks
Denny's makes a stroker crank for a M-450 that uses stock rods but it uses a 4.3" piston that has a special pin location so the stock rods will work but you have to machine the block so the sleeves will fit. www.external_link.com hope that helps.
