Mapleton, MN Pull Sunday June 14th
ReedA
Sunday June 14th
Registration at 9:00 pull starts at 11:00
Hot Foot II sled
Farm stock class 4500, 5500, 6500, 7500 and 8500lbs
Stock class 4500, 5500, 6500, 7500, 8500, 9500 and 10,500lbs
Open class 4500, 5500, 6500, 7500, 8500, 9500 and 10,500lbs
Questions email [email protected]
[b:e7b318a1f4] FARM STOCK CLASS RULES
4500 5500 6500 7500 8500[/b:e7b318a1f4]
1.Antique tractors built prior to 1960
2.Classes may be added or deleted if necessary.
3.Driver must obey flagman at all times failure to so may be cause for disqualification.
4.Any tractor or puller found to be unsafe or illegal may be disqualified or barred from pulling.
5.Tractor and sled must remain in bounds at all times. Out of bounds will result in disqualification.
6.Any weights or parts falling off tractor while hooked to sled will result in disqualification.
7.All tractors must be in line ready to pull at start of each class. [b:e7b318a1f4]TRACTORS MUST WEIGH BEFORE HOOKING TO SLED[/b:e7b318a1f4]. Drivers must remain seated at all times. Tractors must be in neutral when hooking and unhooking from sled.
8.Front wheels of tractor are not allowed to exceed 16 inches off the ground while pulling. A chain and 16 inch piece of pipe will be attached to tractor when hooked to sled. During the pull, pipe will drag parallel to ground. If front of tractor raises pipe off the ground during the pull, tractor will be flagged and distance will be measured.
9.100lb weight allowance for each class.
10.[b:e7b318a1f4]NO CUT TIRES IN FARM STOCK CLASS[/b:e7b318a1f4]. Tires are to be stock size or one size over stock. Tires must be mounted on manufactures recommended rim width. Radials, chains, steel wheels are not allowed.
11.Pump gas, diesel, or LP fuel only. No racing gas, alcohol or nitrous may be used.
12.3 MPH speed limit, blow horn after 75ft you will be disqualified. [b:e7b318a1f4]NO SHIFTING ON THE GO.[/b:e7b318a1f4]13.Custom made weight brackets are not permitted. Factory weights may be used, factory wheel weights, factory front-end weights allowed. Suitcase weight permitted, but may be bolted to frame only.
14.Hitches are to be maximum 16 inches high and locked at 16 inches on tractors such as IH fast hitch, Ford 3 point hitch etc. Hitches must be as from factory-unaltered for that specific tractor. Operator must furnish clevis with a minimum opening of 2.5 inches bolted or pined to drawbar. Farmalls must pull from an original drawbar hooked to the original belly hook point.
15.Stock RPM. Stock block, head, manifolds and carb. If external part is not in the parts book for that specific model tractor it cannot be used. Stock coils & air cleaners must be used. Straight pipes allowed.
16.Tractors must maintain original stock appearance. [b:e7b318a1f4]IF IT DID NOT COME FROM THE FACTORY, IT WILL NOT BE ALLOWED IN THE FARM STOCK CLASS. [/b:e7b318a1f4] No aluminum allowed. Homemade side shields are not allowed. Except factory shields such as Olivers etc. No homemade rear end covers allowed. All guards, shrouds, covers, and shields shall be in place.
[b:5e3d0165f7]STOCK CLASS RULES
4500 5500 6500 7500 8500 9500 10500[/b:5e3d0165f7]
1.Antique tractors built prior to 1960.
3.Driver must obey flagman at all times failure to do so may be cause for disqualification.
4.Any tractor or puller found to be unsafe or illegal may be disqualified or barred form pulling.
7.All tractors must be in line ready to pull at start of each class. [b:5e3d0165f7]TRACTORS MUST WEIGHT BEFORE HOOKING TO SLED[/b:5e3d0165f7]. Drivers must remain seated at all times. Tractors must be in neutral when hooking and unhooking form sled.
8.Front wheels of tractor are not allowed to exceed 16 inches off the ground while pulling. A chain and 16 inch piece of pipe will be attached to tractor when hooked to sled. During the pull, pipe will drag parallel to ground. If front of tractor raises pipe off the ground during the pull, tractor will be flagged and distance will be measured. Applies to all tractors with or with out wheelie bars
10.[b:5e3d0165f7]NO CUT OR SHARPENED TIRES[/b:5e3d0165f7]. Maximum tire size to be 18.4x38. Standards max size 23.1x26 Tires may be mounted on any rim width. Radials, chains, steel wheels are not allowed.
12. 3 MPH speed limit, blow horn after 75ft you will be disqualified. [b:5e3d0165f7]NO SHIFTING ON THE GO[/b:5e3d0165f7]
13.Suitcase weights and custom made weight brackets are permitted. Front weight bracket not to extend no further than 11 feet form center of rear axle.
14.Hitches to be minimum of 18inches back from center of rear axle and max of 20 inches high. Hitch material cannot be thinner than ¾ inch and not thicker than 1.25 inches. Hitch to have 3-inch dia. Hole with 1-inch material thickness around hole. Clevis may be bolted or pinned to drawbar. Hitches and drawbars must be stationary in all directions.
15. 10% overstock RPM. Stock block, head, manifolds and carb. If external part is not in the parts book for that specific model tractor it cannot be used. Electronic ignitions allowed, air cleaners must be used although ant type may be used. Straight pipes allowed.
16.Tractors must maintain original stock appearance. No aluminum allowed except for weight brackets and wheelie bars (if equipped). Homemade side shields are not allowed. Except factory shields such as Olivers etc. No homemade rear end covers allowed. All guards, shrouds, covers and shields shall be in place.
[b:7a27096963]OPEN CLASS RULES[/b:7a27096963]
1. Antique tractors built prior to 1960.
2. Classes may be added or deleted if necessary.
3. Driver must obey flagman at all times failure to do so may be cause for disqualification.
4. Any tractor or puller found to be unsafe or illegal may be disqualified or barred form pulling.
5. Tractor and sled must remain in bounds at all times. Out of bounds will result in disqualification.
6. Any weights or parts falling off tractor while hooked to sled will result in disqualification.
7. All tractors must be in line ready to pull at start of each class. [b:7a27096963]TRACTORS MUST WEIGHT BEFORE HOOKING TO SLED[/b:7a27096963]. Drivers must remain seated at all times. Tractors must be in neutral when hooking and unhooking form sled.
8. Front wheels of tractor are not allowed to exceed 16 inches off the ground while pulling. A chain and 16 inch piece of pipe will be attached to tractor when hooked to sled. During the pull, pipe will drag parallel to ground. If front of tractor raises pipe off the ground during the pull, tractor will be flagged and distance will be measured. Applies to all tractors with or with out wheelie bars
9. 100lb weight allowance for each class.
10. [b:7a27096963]ANY CUT TIRES ALLOWED[/b:7a27096963]. Tire size to be 18.4x38. Tires may be mounted on any rim width. Radials, chains, steel wheels are not allowed.
11. Race gas, diesel, or LP only. Alcohol may be used. (in tractors only).
12. Any gear, any speed, within reason, may be used.
13. Suitcase weights and custom made weight brackets are permitted. Front weight bracket not to extend no further than 11 feet form center of rear axle.
14. Hitches to be minimum of 18inches back from center of rear axle and max of 20 inches high. Hitch material cannot be thinner than ¾ inch and not thicker than 1.25 inches. Hitch to have 3-inch dia. Hole with 1-inch material thickness around hole. Clevis may be bolted or pinned to drawbar. Hitches and drawbars must be stationary in all directions.
15. Any RPM kept with in reason. Stock appearing block, head may be aftermarket. [b:7a27096963]NO AUTOMOTIVE V-8’S[/b:7a27096963] Manifold may be of any design. Carburetor may be any agricultural type. Electronic ignitions, MSD ignitions, alternators, straight pipes allowed. Air cleaners must be used although any type must be used. Run what ya brung!
16. Tractors must have stock frame, transmission, rear end and axle housing. Aluminum allowed. Homemade side shields and rear end covers allowed. All guards, shrouds, covers, and shields shall be in place.
