Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
How to get more hp out of a Farmall H
JoeyF
03-22-2009 17:43:11
Hi I am building a H for pulling and want to get more horsepower out of it. I have already rebuilt the bottom end with steped head pistons. I have had the motor running and it runs good but it only makes 80# of compresion with the rings not broken in with the original head. Now I am looking for a 350 lp head to raise the compresion higher. The next step is to build a manifold similar to a farmall M LP intake and use a farmall M carb. The problem is I want to get a camshaft but I am not sure what to use. I dont know if I should get a 350 cam or have one reground to different specs? Also if anyone has any other tips or tricks it would be greatly apriciated. Thanks Joey
Black farmall
03-25-2009 06:13:01
 Re: How to get more hp out of a Farmall H in reply to JoeyF, 03-22-2009 17:43:11
If you get the compression up, Air into the engine and air out of the engine is how you make power. the better it breaths the better it will run.( longer stroke,bigger valves, regrind cam ect.)
t hayes
03-23-2009 16:07:24
best thing to do is sell or give it away and buy a john deere just kidding but i couldnt resist good luck with your project
Should Help?
03-23-2009 10:06:56
THE BLUE BOTTLE:)
buickanddeere
03-23-2009 07:32:12
The factory cam and followers will be worn. Even regrinding them back to stock specs will increase power.
garytomaszewski
03-22-2009 20:22:53
Joey, Generally when talking about rebuilding the bottom end of an engine people are refering to the crank/rod bearings. With step head pistons that 80# sounds awful low even for a kerosene head. Building a manifold may help, but unless you are using E85 the M carb might just over fuel you, only way to know for sure is on a dyno. If you get another head, just use all the old hot rod tricks; port, polish, match intake/exhaust manifolds to head.
MLPANKEY
03-22-2009 18:32:19
JoeyF said: (quoted from post at 17:43:11 03/22/09) Hi I am building a H for pulling and want to get more horsepower out of it. I have already rebuilt the bottom end with steped head pistons. I have had the motor running and it runs good but it only makes 80# of compresion with the rings not broken in with the original head. Now I am looking for a 350 lp head to raise the compresion higher. The next step is to build a manifold similar to a farmall M LP intake and use a farmall M carb. The problem is I want to get a camshaft but I am not sure what to use. I dont know if I should get a 350 cam or have one reground to different specs? Also if anyone has any other tips or tricks it would be greatly apriciated. Thanks Joey
I am not a h man but 80lbs sounds verry low for a puller. my opinion
joeyf
03-22-2009 19:19:17
 Re: How to get more hp out of a Farmall H in reply to MLPANKEY, 03-22-2009 18:32:19
That is the reason I am looking for a 350 lp head. The head I used was the original kerosene head. I used it just to see what I had to work with.
Full Pull H
03-22-2009 20:04:51
 Re: How to get more hp out of a Farmall H in reply to joeyf, 03-22-2009 19:19:17
Get rid of the kerosene head it is junk!The lp head will help if you can find one for a good price. Another head to look for is the 8043 "gas" h head sometimes you can find them cheap then put money in to it for the same price as a basic lp head. The right piston helps alot also for compression. I have seen a lp head on a tractor but with no compression do to the wrong pistons.
Full Pull H
03-22-2009 20:32:05
 Re: How to get more hp out of a Farmall H in reply to Full Pull H, 03-22-2009 20:04:51
Oh yeah, send a cam out and get it reground. Well worth the money and good manifolds are the 350 gas or the Johnson LP ones then put the M carb uunder that. A 350 carb can be made just as good as a m carb though if the right person does it. There is alot of things to get horse power out of a h. The best is a stroker crank though!
RareBird
03-23-2009 19:22:28
 Re: How to get more hp out of a Farmall H in reply to Full Pull H, 03-22-2009 20:32:05
You can get some tips on Farmall H's from CliffS I heard he has one that works well and looks good too.
