Hi I am building a H for pulling and want to get more horsepower out of it. I have already rebuilt the bottom end with steped head pistons. I have had the motor running and it runs good but it only makes 80# of compresion with the rings not broken in with the original head. Now I am looking for a 350 lp head to raise the compresion higher. The next step is to build a manifold similar to a farmall M LP intake and use a farmall M carb. The problem is I want to get a camshaft but I am not sure what to use. I dont know if I should get a 350 cam or have one reground to different specs? Also if anyone has any other tips or tricks it would be greatly apriciated. Thanks Joey
