Cheap Electric Water Pumps
Im looking for a cheap but still a dependable and decent quality electric water pump. Does anyone know where I can find one?
Thanks
Here is an intercooler pump off of an 03 F-150 Lightning Ford pickup. Best deal you will find for something that is already set up for antifreeze.
http://cgi.ebay.com/ebaymotors/03-F-150-Lightning-intercooler-electric-water-pump_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem120339705424QQitemZ120339705424QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
I use the Lightning one shown below. The trouble I've had is I haven't been able to find the right electrical connector for it so I had to make one.
If anyone knows where to get the connector, please let me know. I called a couple of Ford dealerships and they were useless.
Go to TSC and get what they call a sponge pump. Or go to mytscstore.com and type sponge pump into the description. 85.00 Work great.
get one of a school bus that is used to get warm coolant to the rear heater. If you were to put some non-cut tires and an original manifold you could pull your B in class one and probably would be very competitive.
yeah that is true. i should probably pay more attention but is there very many class 1 3500-4000 pullers? i need a water pump so i dont have to build an upper water pipe for my latest manifold. and then i wont have to build one for the next one or the one after that.
I am using one from Northern Hyd. or maybe just Northern now It is just garden hose size and pumps 5 gal per minute. It will keep a 2-53 detroit cool. It comes with a spare impeller and seal I am running antifreeze. the cost is about 50.00
(quoted from post at 02:18:30 11/26/08) I am using one from Northern Hyd. or maybe just Northern now It is just garden hose size and pumps 5 gal per minute. It will keep a 2-53 detroit cool. It comes with a spare impeller and seal I am running antifreeze. the cost is about 50.00
I will have to check that out. thanks
Calvin Tilbury's H , Rodneys WC and Hagena's 30 Cockshutt will give you plenty of competition in class one! I would like to build a 77 Oliver to play with them.
Thanks to Reed for matching up my picture with the right part number.
You can order thru Ford. The Motorcraft part number for the connector to the Lightning Water pump is
3U2Z-14S411-BJA
it's about $23.
