How Much Bore For Farmall M?
1 morgan
New User
First is a farmall M the same block as a 450? How much can you bore this ?, and how many cubes would thi make? thanks for any help.........
A 248 block you are usually safe at 4-1/4", a 264 and 281 block you can go 4-3/8" but you really should sonic check them to make sure you have enough cylinder wall thickness.
Well it came from Bakers shop so it ran pretty good. At 696 cubes I think he has exceeded what the head can flow. Beduhn ran it for a year then it went south some where.
