Anonymous-0
I have a 1949 model
I have a 1949 Model A John Deere, with 530 cu. in. The problem I am having is I have to tightened the clutch so tight to keep if from slippping in higher gears that it is hard to engage and dissengage. It has the older two disc clutch set up. I was wondering of you can convert this over to the newer three disc setup used on later John Deere A's. THANKS.
