truck bed reinstall
MSS3020
I had to remove bed to replace fuel pump and while its off replacing the bed supports that hook to frame.. Question is why I need to spot weld new ones on. Why cant I place them on frame and then lower bed down and bolt the bed and supports to frame.. why wouldnt this work.. my mind tells me it would..
thanks
The only issue I can think of is the nuts might vibrate off. If you are going to use bolts I would use some threadlock. It also might help to take a screwdriver and damage the threads on the bolts sticking out from the nuts.
I think a quick tack-weld on any exposed threads will keep the bed bolts tight till they rust off again. Depends where you drive the truck, I'm in Wisconsin, I've seen terminal cancer on 5 year old pickups. I've seen Arizona cars, even 3-4 year old WHITE cars fade.
