Spray paint Farmal C rim
560Dennis
Location
Madison,Ohio
Im going to spray rim after I sand out all the runs and rust of an older rim with 11.2x36 Goodyears mount.
How do you keep the spray off the tire ? Use grease ? Tape ?
I let all the air out of the tire, then with tire irons I ease the tire down just enough to put file folders in the gap, I have a set that I keep that already has the correct radius out in them, makes it very easy to get them in. In the past I have also used cheap playing cards and 3x5 note cards
I took an old aluminum license plate, trimmed it in a circle to match the rim curve, and slide it around as I spray. Works perfect. BTW, I spray Rustoleum Hammered aluminized looks good, all the drips and runs I make make it look like galvanized.
