Brush Paint
in order to minimize brush marks, a more expensive brush that has finely split tips on the bristles works better than the cheap ones. Foam brushes can work well on the bigger flatter parts. The tricky part is going to be the reaching down into corners and tight spots in between places where spray would get right in. Expect the paint to get dull in a few months unless you add hardener and of course take the necessary precautions.
Brush painted these. Rust oleum paint. Cheap dollar store brushes. Good hot day. Hours of cleaning before painting. 3 coats. Little thinner in the paint. Always kept in a shed so color is still bright.
We hired a man and helper to paint City Utilities well houses once, and he mixed up all the two-part epoxy and brushed it on with kitchen brooms.... a nice sky blue. He got it done, had several gallons left over, asked what we wanted to do with it .... we said it's all yours. He and helper looked around, walked over to the work truck with trailer, tool boxes, etc., and brushed it all a nice blue epoxy. Saw him around town for years afterwards, beautiful sky blue, it held up well...... looked just fine, ...... from a block away.
those are some pretty critters, and who has the steady eye and hand for all the scroll work?
can you paint Oliver Green that well too! LOL. keep posting those pics. GG wes
Use as soft a brush as you can find and you might add a little Flood Penetrol to the paint. This additive slows the drying time of the paint down a little to make a smoother finish. When brushing paint apply the paint as thin as you can with as few strokes as possible. The more you brush paint the faster it sets up and causes the brush marks show more.
Use as soft a brush as you can find. Doesn't have to be an expensive one. Brush the paint on as thin as possible with as few strokes as possible. The more you brush paint the more the brush marks show. It would also help to add a little Flood Penetrol to the paint. It slows down the drying time to enable it to flow out better.
Some people recommended me Rust-Oleum 7424502 and Majic Paints 8-0962-2 Town & Country Tractor. I can say that both are really good.
(quoted from post at 20:04:11 01/31/22) Some people recommended me Rust-Oleum 7424502 and Majic Paints 8-0962-2 Town & Country Tractor. I can say that both are really good.
Yes homer, I use a fair amount of Rustoleum, but I wouldn't use it where a smooth, long lasting, bright, non-fading finish is desired. I wouldn't use Magic for anything. It ll depends on what your expectations are, and how much time and effort you put into your preparation.
The general rule is to use natural bristle brushes for oil-based paints and synthetic bristle brushes for water-based paints. Synthetic bristles can also be used with oil paints, but you don't want to use natural bristles with latex.
A good brush is not cheap, but you'll be happier with the results if you use an expensive brush versus a throwaway. You will need to spend some time cleaning the brush afterwards. A brush with tapered bristles will leave the least amount of brush marks.
Read about British coach painting on the internet; they were/are masters at getting a fine finish using
brushes. One of the tricks is flowing out the paint while brushing. Another is 'flatting the paint. After
drying, wet sand it with progressive finer wet-dry paper, then buff it out.
They use the old techniques a lot for restoration of carriages, canal boats, and old busses, where this
technique was often used originally.
(quoted from post at 11:44:21 03/15/22) Read about British coach painting on the internet; they were/are masters at getting a fine finish using
Both of those procedures are commonly in use in auto-body shops here in the US every day.
(quoted from post at 13:02:45 03/17/22) Does any one know when production products switched from brush painting to spray painting??
I can't imagine that they would ever have brushed.
