Oliver-Hart Parr Paint for radiator
jpi72
I have a radiator top that says Oliver and Hart Parr. I think it is either gray or a dark green. Can you tell me the color it should be, and a possible source?
Joel
Not sure what you have for model/year but either way I believe it should be some shade of dark Oliver green with lettering most likely being
red. If you have a 70 it was the last tractor to have the Hart Parr name on it albeit small under the much bigger Oliver name see attached.
(quoted from post at 10:29:30 01/15/22) Not sure what you have for model/year but either way I believe it should be some shade of dark Oliver green with lettering most likely being
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto114133.jpg>
I called an Oliver friend and he said it was the Dark Oliver. Thank you for your input. Sharp tractor, is that yours?
