Talk to your local automotive paint store. They may be able to fix you up with some automotive base/clear that is in rattle can. Really your best bet would be to refinish the area you are having problems with and epoxy prime and use a single stage urethane. The problem then is you would either have to come up with some excellent ventilation or get an air supplied respirator. Basically if you can smell that paint at all it's hurting you.
study the difference between 1k paint and 2 k paint 2k using a hardener completely gas resistant. Spray cans come in 2 k .
