Ford 8N medium gray
I am looking for a modern urethane paint to match the medium gray paint on my 48 8n. The only paint that I can find is Tisco tp240 or Sparex tp240 and both of these are old style synthetic enamel. I have found a modern paint for the red. I would like the newer acrylic urethane paints that stand up longer with out fading or dulling.
If it were me I would use an acrylic enamel. I've only used one urethane, Dupont Nason and it's not wearing as well as Rustoleum Farm and Implement enamel. Then a Urethane contains Isocyanates. You really need to suit up and use an air supplied respirator to use it. I
thought if I was careful I could get away with painting one tractor without the proper equipment. I painted the tractor and used 2 gallons of Nason outdoors with a cartridge respirator and held my breath when down wind from the overspray. Afterwards I coughed for
six months.
I used PPG paints MTK Acrylic urethane with hardener.
Must use supplied air system with hardener
PPG 32675 Ford Gray
PPG 70075 Vermillion Red
PPG 8568 Silver Gray some call it Argent Silver for rear rims
31657
