[email protected]
New User
Last fall I was able clean my parts and get primer on everything. Winter happened so without a heated shop I had to pause. Other projects jumped
ahead this spring. I now have some parts that are dusty and others that are dusty and have spots of WD-40 on them. Do I just use the pressure
washer on the dusty parts? Do I need to use phosphoric acid on the WD-40 parts again or will carb cleaner suffice? Will that hurt the primer? How do
I clean up the WD-40 parts? Some advice would be greatly appreciated!
