Ospho and body putty
chuck machinist
I have prepared an Ospho solution sprayed on to a few non-
critical non-seen parts on a tractor. Should asphalt be brushed
or washed off after drying, so that I might apply a small
amount of body filler before prime and paint. CM
I use a different brand of the same type of product. After applying the product following label instructions, so that it has formed the protective coating, I wash it aggressively with water in order to remove the excess so that the filler or primer can bond to the metal with no residue to interfere with the bond.
