1946 BN IHC
Purchased a "rubber" wheel from car quest. Works wonders on decal removal. >>Discovered that it also helps remove silicone that some one hade used to calk joints. <<
!!!! For peace of mind >>>>""NEVER""<< use silicone THROUGH IT AWAY it is the worst material on the market might look good but NEVER closes the joint. THERE IS a product that may be purchased from roofing company supply outlets. The name was Kop-r-lastic. there is an up date of this now. It has a rubber component in it. it will last for 20 plus years when installed properly and evenly. Small joint, let dry; then spread a second layer for bigger joints.
This is the best calking out there.
Thank you again for the information re removing decals.
Wm.
Wm.
