Enamel cure time
Ultradog MN
Location
Twin Cities
Going to shoot some Tisco enamel this
afternoon. Will use my usual recipe of
paint, hardener and lacquer thinner.
Am going to shoot it in a corner of the
shop that I have temporarily walled off
and heated to about 75 degrees with an
electric heater. Will pull the heater out
while I shoot but put it back in there
afterwards.
I don't want to heat it forever so
afterwards the temp will drop back down
to about 25 degrees. How long should I
leave the heat on and how long afterwards
to cure?
Thanks.
. I was told by my paint rep that the curing will stop below 60 degrees, I would keep the heat on as long as you can.
the paint spec i used for bridge painting contracts called for 48 hours between coats at 50 degrees and 85% humidity max
I would think lacquer would cure quicker
Thanks guys.
I shot it about noon yesterday.
Checked it at 8 pm and it was still sliiightly tacky.
Just checked it again a bit ago and it's dry to the touch but I can dent it with a fingernail. So it's drying but slowly.
Normally when I shoot parts it's spring or summer and it drys to the touch in about 4 hours. The temp is about 60 degrees in there.
Supposed to get up to about 40 here on Sunday.
I'll keep it heated till then and then I'm going to stick it in the tractor.
At that temperature just keep the building hot enough until it's dry enough you can press your thumb hard into the paint and it doesn't leave a print. From there ventilation will do more than heat. Still it would be at least a month and could be as much as two months before you could call it cured. If it were me though I would just let it dry 3-4 days and go ahead and install the engine. The worst that can happen is a rub mark on the paint which could be touched up. Just don't mix the touch up paint with lacquer thinner. There will be a recoat window and lacquer thinner has acetone in it which is a very hot solvent.
