NAPA 102 epoxy primer
David G
Can someone tell me the drying time for the NAPA PIP 102 primer?
I have searched high and low.
Thanks.
Go back to Napa where you bought it. They should have a data sheet available for that primer. It's more or less instructions that should be on the can instead of hazard warnings in three languages.
I hope you haven't already started using it. Most epoxy primers have a recoat window which means you have so many hours between the time you spray it and when it has to be topcoated. If you go past this window you need to sand it and put a second coat of primer on.
