keeping paint from freezing
Dune Country
I just moved from a temper claimant where it rarely freezes to a climate where it gets down to 0 sometimes. I have quite a bit of automotive paint.
I have a insulated room in the barn and have a old double wide fridge and was thinking of just leave the lights on in the fridge and use that.
Your thoughts?
Unless it's a waterborne automotive paint it wouldn't hurt for it to freeze. It's heat that will damage a solvent coating. Because of that the paint would last longer if you kept it in a refrigerator.
I don't heat my shop when I'm not working in it, and I've never had a problem with petroleum based paint freezing, even though it gets down to zero or colder here. Waterborne might be affected, but I've never gotten into that.
The solvents in paints freeze at a temp much lower that water. shouldn't be an issue unless your shop get to -30 or so
Solvent based paints if it did freeze would dissolve back together once it thawed. Waterborne finishes tend to separate when they freeze and don't reconstitute themselves.
