87nassaublue
This message is a reply to an archived post by Tylerpresser14 on March 20, 2018 at 05:30:29.
The original subject was "What do you use to seal off areas while blasting".
Green painters masking tape is good to close off ports and protect areas you don't want sand blasted. Be careful about blasting with engine covers off. Sand will get in places you can't see and can cause engine failure. Been there, done that.
