Tractor Paint
pat sublett
I have used tractor Supply?s Magic junk paint and swore that I would not use it again if they gave it to me. However I noticed Tractor Supply had Rustoleom Tractor and Machinery paint. Has anyone used it, can you add hardener to it?
I used the plain old rust-o-leum that you can buy for $9 a quart at homedepot to paint my 135, and 2135. I mixed in a little enamel reducer, added the hardener as per instructions, and used a $20 HVLP spray gun from HF. The rust-o-leum tractor paint is probably the same stuff (but the color probably matches the original color better). The paint on both my tractors are holding up very good
I have used it and for an alkyd it's about as good as it gets. I painted a Kubota tractor a little over a year ago and it's still the same color. A hardener will work well with the paint too.
