showcrop
I have never used aircraft paint stripper, so due to the debate about it in the prior thread I googled it, and also looked up the SDS on it. If you are going to use it you need to read up on it. DO NOT USE IT INDOORS! It is nearly straight DiChloromethane which is a pretty bad solvent.
"For OSHA controlled work place and other regular users. Use only with adequate ventilation under engineered air control systems designed to prevent exceeding appropriate TLV. For occasional use, where engineered air control is not feasible, use properly maintained and properly fitted NIOSH approved self-contained breathing apparatus for chlorinated solvent vapors. A dust mask does not provide protection against vapors."
Being solvent based it is safe on aluminum where caustic oven cleaner will attack it.
