TractorLinks.com
Truck frame paint
Danney970
02-09-2018 13:21:54
I am getting ready to sandblast and international 4700 truck frame to be put together for a grain truck I want the thing to last what is your recommendations for priming and painting por15 paint I see mixed reviews on. Not sure if this is the best way to go just paint with por15 and forget about looking for any and all input. .
MSM
02-13-2018 06:13:55
 Re: Truck frame paint in reply to Danney970, 02-09-2018 13:21:54
Used to be a paint called frame saver or chassis saver. Don't know if it's still around or not. It was very similar to the factory paint used on frames years ago. I painted a truck frame with it years ago,it held up very well. If you got it on your hands, nothing would get it off, not acetone,or lacquer thinner, it had to wear off.
glennster
02-14-2018 11:54:42
 Re: Truck frame paint in reply to MSM, 02-13-2018 06:13:55
chassis black, eastwood sells it
Duane WI
02-09-2018 17:09:53
I have never used POR15 but have read you must follow the instruction to the penny. I have read stories of it pealing off when directions where not followed. I have also seen the results when done correctly and it looks great. One word of caution is POR stands for Paint Over Rust. It is meant to paint over rust. Not sure how it works on sandblasted surfaces. POR15 has a special wash solution and acid etch solution to use before applying the top coat.
If it was me on a sandblasted frame I would epoxy prime and top coat with black Rustoleum. If you just want to knock the rust and dirt off with a wire wheel then POR15. If you are worried about some small rust specks left after sandblasting then you can use an acid solution like OSPHO. Just make sure the epoxy primer is okay with acid prep. Some epoxy primers are fine with acid some are not. I have used Omni epoxy primer over OSHO with no issues.
showcrop
02-09-2018 15:30:09
I have never seen anything but good reviews of POR 15. I would think it unwise to paint without it after sandblasting, because there are always tiny specs of rust in the pits that will cause bubbles in the paint in as little as 2-3 years.
MI-Bill
02-15-2018 18:15:41
 Re: Truck frame paint in reply to showcrop, 02-09-2018 15:30:09
I always keep some around. have used it on old equipment, dusty pieces where it was difficult to get clean and not really worth to much effort. my experience it never peels. bites into most anything. on jobs I care about I will litely sandblast. have used epoxy primer on properly cleaned parts on trucks and had the Poor 15 areas hold up better 5 years later.
