Cormiers Cove
Has anyone used the oil based Alkyd paints over Epoxy primer and what did you do to prep the surface prior to painting?
I used AGCO paint over epoxy primer with no prep work the day after the epoxy was applied and I have mixed results. The AGCO paints use acetone for a thinner and I don't think they bite into the epoxy primer that well.
After doing some research I have determined that using Alkyd single component paints such as the AGCO paints are not recommended to use over Epoxy primer.
I guess I should have a used a urethane paint or an epoxy paint over the epoxy primer.
