GregtheDC
I have just purchased a set of decals for my T6 crawler, Mylar, and need the correct directions to apply, can anyone help?
Thanks
Greg
spray area with soapy water, wipe clean, spray again, peel off backing and apply wet, adjust if necessary, squeegee out water, carefully peel off covering.
(quoted from post at 22:00:33 10/20/17) spray area with soapy water, wipe clean, spray again, peel off backing and apply wet, adjust if necessary, squeegee out water, carefully peel off covering.
Windex works also. Lets a guy move the decal around a bit before it is permanent.
