I have an HVLP gun from TSC...not a great gun but I'm trying to use it. I have a regulator at my compressor and there is a regulator that goes on the gun. Any suggestions as to where to set the psi's for each when I try to spray? I'm using primer first and then will use paint. The primer seems a bit thicker but I plan to thin them both....
Any suggestions or advice is appreciated in advance. May not be a real good gun but was not their cheapest one. I bought paint thinner for clean up and the little brushes for clean up.
thanks, MO
thanks, MO
