case ih iron guard paint
Lee460
I am going to spray some panels with IH 935 blanc white. I always used just Tractor Supply oil based enamel in the past with there hardener and had good luck for someone that has no ideal what he is doing. My question is the 935 a oil based enamel that I can use the hardener I have or do I need something else, or nothing at all? Thanks for any help. Jim Lee
You can use the same hardener but it might be better to use theirs. The hardener will make the enamel dry harder and improves gloss. The improvement in the gloss is enough reason to use it. The glossier the paint is the more durable it is because it sheds water better.
