mixing/tinting paint
SDE
I have a can of light gray paint and some black that is the same brand. I am thinking of mixing some of each in a separate container to see if I can make the light gray a darker shade of gray. Any reason that it will not work?
TY
SDE
That will work fine but be sure to measure the amounts of each in case you need some more. Also keep a record in case you need to make some more for touch up.
Thank you. I have almost a gallon of light gray and I would like to use up to get rid of it.
TY
SDE
