I am working on a 1950 Chevy Pickup. On the door exterior at the base of the window there are small rust holes all along the edge. This is normally covered by a piece of trim but the rust holes are large enough to just be starting to come out beyond the trim. I am trying to figure the best way to repair. I have tried wire welding small rust holes closed before and it usually ends up in a mess as the metal is thin and the holes just keep getting bigger as you try and weld them closed. I think I can make a patch panel but this is a complicated area because there is a small bead around the window and a large body line bead right below it. I am thinking about sand blasting the holes and then filling them with JB Weld. Any thoughts? Thanks for the help.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto1334.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto1335.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto1336.jpg"/>
