TJ in KY
I have used PPG Omni paints to paint the tractor, with hardener. I was wondering if I should mix the paint the standard 4:1:1 or should I reduce the reducer to ½ or eliminate the reducer altogether. I will be brushing or dabbing it on and I plan to practice on a junk hood and fender that I have laying around.
Also should (when) I get some red where I don't want it what would be safe to use to wipe it off, paint thinner or reducer or ??The paint has been on the tractor since last fall but I have been doing a little buffing and polishing on it lately.
I plan to sand the top of logos lightly with some sandpaper 1000 grit before painting and cleaning the area with wax and grease remover.
Any tips or tricks would be appreciated. If you see a flaw with my plan let me know also.
