How much paintreducer will I need?
Philip d
We want to paint a high dump wagon we just bought. It's 12' long the sides are @8' each the front &back average width is 6,5',back height is 10.5' and the front is 7' as the top is open to blow feed in. There's also a wagon under it and some frame work on one side. If I give it 2 coats rough math with the wagon would be @800' square? Depending on price I may use a standard hardware store rust paint. I don't paint that often ,I think I mix it @25% reducer,would that be a good amount? Also I was considering sand blasting the stickers off,would those areas need primer before paint if it's only rust paint? I may also blast some of the rust spots as well. If that would work what type of grit would work best? I don't need it to look like or better than new when it's finished but I would like it to look respectable when it's finished.A lot of questions I'm sorry and thank you for any advice.
Oops,I was also wondering based on that square footage how much paint I will need? Sorry
What kind of paint are you using? A lot of paint 25% would be too watered down. You would probably be better off getting the specifications on the paint you are using. Often over thinning paint screws with the sheen and integrality of the paint. Oil based enamels for example you want to thin it as little as you can.
'You need to check the label of the paint for coverage, and for thinning. A 40 grit flap wheel in a grinder is great for rust and loose paint removal. use some Rustoleum primer on all of the bare metal. The existing paint is likely to be chalky so you will need to get the chalk mostly off. It would be worth buying a cheap DA sander at Harbor Freight for that.
Thank you,I was thinking on using a rust paint,I'll see what is on the label on the can for mixing instructions and go with what they say.
