I have a 2640 that looks.... tired. It is very much a work tractor but I want to do a somewhat fast and dirty paint job on it. To me that means leaving the tractor mostly together while pulling off easy stuff e.g. (hood, fenders, come off). I would powerwash, sand and fix rust in specific areas but not sandblast entire tractor.
I have seen the tractor supply store JD green paint and thinner that I would use... get a spray gun to lay down the paint. My questions are:
- What do I do about engine? Do I simply block intake and exhaust, clean it, and shoot paint?
- Anything else I should be concerned with?
I will probably do a little sanding here and there to fix runs and what not but trying to keep it as a work tractor so if it isn't perfect that is just fine.
Thanks
Kevin
Thanks
Kevin
