I am looking for a primer or process that allows me to topcoat on fully cured primer, without prior mechanical sanding/scuffing. Thinking tractor/equipment parts, intricate detail or cast. I strip, de-rust or blast, clean, dry. At that point I want to prime and then set it aside for months. When I get ready to top coat, I want to wipe down and top coat, no scuffing. It would be ok to wash down with a de-glosser or something to get tooth. Then I topcoat with 1k or 2k.
And oh, I would prefer a 1k in spray can primer. it would be ok to hit it with two different primers right after blast, such as an etching primer, then followed up with another primer that has the no-sand required characteristics. Thank you.
