Sand blast or prime
Rons b
I had all of the misc. parts of the tractor except for the sheet metal. Blasted and primed. Then there was a fire. all the parts are now black with soot. Should I just clean sand the parts and re-prime or should I sand blast them again.
Despite the fact there is soot all over the primer is probably still bonded to the surface. I would sand off all soot but not re-blast.
Sand blast as little as possible. I would just clean off the soot.
Cast metal if you want to can be blasted again but tin ware never!
MHO.
