Easy to Remove Rattle Can Primer
I am working on a very rusty Farmall just trying to get it running. While working on it I try to clean it up as I go. Does anyone have an idea for easily removable primer I can spray on cleaned up parts? Eventually I want to do it right with an epoxy primer so this is just an "as I go" solution to keep more rust from developing after I wire brush it while I work on it.
primer wont seal out rust, it needs the color over it to "waterproof " it. buy a couple cans of farm and fleet tractor enamel spray cans and paint it on. it will come back off pretty easy with either lacquer thinner or gasoline . then later on when you are ready you can strip the paint off and start work.
