Adjusting an air compressor pressure regulator
Painter48
New User
Does anyone know if the pressure regulator from a Campbell Hausfeld air compressor model VT558705AJ can be adjusted to a higher pressure setting? Thank you.
You should have a gauge on the compressor showing the pressure in the tank. With the regulator opened wide open the pressure at the regulator should be the same as what is in the tank. If it won't, then the regulator probably needs to be replaced. I normally set up one coupler right off the tank and one through the regulator. That way if you need full pressure there isn't anything to adjust.
