metal glaze
chuck machinist
I'm using Fast Line fast flo glaze, and Dynatron putty coat separately in applications . Golf ball amount and 1 1/2 inch length of hardener . Having a hard time with working time, so I cut back to 1" length . Still short cure time. About 2 minutes Temp today was 73* 60% humidity. Any thoughts on getting a longer working time with the product? Thanks in advance Chuck
they never take what it says to use accept in winter maybe. Cut it even more. You should get at least 5 min work time. 1 1/2 " for a golf ball size is way too much if over 60 degrees. Everything's an experiment.
Thanks Randy. Decreased my hardener, and getting better results. Just have to wait a little longer for drying. I do not have a problem with that.
